HP Forum Archive 01
48GX/SX and 95LX PC I/F cable
Message #1 Posted by Bruce Riggins on 12 Nov 1999, 11:22 a.m.
Does anyone know if the PC I/F cable for the 95LX is the same one used on the 48 series?
Thanks.
Bruce
Re: 48GX/SX and 95LX PC I/F cable
Message #2 Posted by Andrés C. Rodríguez on 12 Nov 1999, 1:21 p.m.,
in response to message #1 by Bruce Riggins
If you buy the cable for an LX100 (I assume it is similar in the LX95 case), you also will receive a 4 pin to 10 pin converter (a small plastic píece about 1 cm on each side). This converter allows the cable to be connected to an HP 48 calculator. The other end is a DB-9 connector, for PC use.
Message #3 Posted by phillipe on 13 Nov 1999, 12:15 p.m.,
in response to message #2 by Andrés C. Rodríguez
www.hpcalc.org ....go to the buying guide section at the bottom for complete info. 100lx cable can fry a 38 (sends 12v), not sure about a 48?? 95lx cable should work though
