Re: Tracing Curves Message #3 Posted by Eduardo on 25 Oct 1999, 9:59 a.m., in response to message #2 by Reinhard Hawel
Reinhard: Normally I wold apply voltage using a variable DC source on a simple circuit including just the diode and a resistor. I place a multimeter in the diode until the reading reaches a desired point. Then I wold check the current. I do this for both: forward and reverse bias.
With the above results a trace a curve on a X Y axis using pencil and paper.
What I am looking for is a way to trace the curve feeding the data to the 48sx and sending it to the printer.
Also: Do you know of a dedicate software that wold do this?
In advance thank you.
