Re: Copy a stand alone program from a library. Message #2 Posted by Joe Panico on 12 Oct 1999, 11:17 a.m., in response to message #1 by Tal
Tal,
You can selectively remove programs from a library but not through any conventional (48 User RPL) means. Some "hacker" programs are available at hpcalc.org, but you will need an understanding of the calculator to make use of these. If the "split" programs make use of System RPL or assembly, then an additional obstacle stands in the way. If your are concerned with memory, add a 128K card. If both ports are used for library cards and you want yet another, well .....
Joe
