hp 42s programming Message #1 Posted by William L. Drylie on 10 Sept 1999, 2:47 p.m.
I need help finding a corresponding keystroke or sub routine for the 42s that corresponds to the regswap command in 41cx programming. I have an old hp67 program I use frequently in my work that is rewritten for the 41cx and I want to use it on my 42s. The 67 program used the primary and secondary register exchange, the 41cx used a specific block of registers specified by size of block and location to exchange data. I can find no corresponding keystroke sequence in the 42s manual. Maybe someone else has run across this problem? If someone has a solution I would appreciate the help, or drop in and say hello. Thank you.
