Re: HP-9114B Disk Drive Message #5 Posted by Gerry on 13 Sept 1999, 11:10 a.m., in response to message #4 by Walt Devaney
So you sent it? I only got it this morning and I just sent you an E-mail reply. Thanks for sending it.
I replaced the battery on the 9114B (I used the info from your 5/10/99 post, on the HP Forum Archive, among those by others) and it appears to be working now. I'll need to test it further, though.
One of the most helpful pieces of info in that pdf file was the "Power-On Selftest", which I'll quote for the possible benefit of others:
"A power-on selftest is performed automatically when you turn on the disk drive. The test light (on the right side of the front panel) is on when selftest is in operation. The selftest takes approximately 6 seconds after which the test light goes out. If you have a disk inserted in the drive, read and write testing (involving the disk) takes an additional 5 seconds or a total of approximately 11 seconds. If the test light stays on after the normal testing time, an error within the disk drive (such as write protection - my note) has been detected."
