Re: HP GROB file string in level 1 to an executable file? Message #2 Posted by Steve Simpkin on 9 Sept 1999, 1:17 a.m., in response to message #1 by Tal
One easy way to view a GROB in level 1 (for example: Graphic 131 x 64), is use the following program to view it.
You can then use the arrow keys to scroll around the image if it is larger than the screen. Press NEXT NEXT then the KEYS menu button to tun off the menu.
There is likely a cleaner way to do this, but this works.
