Re: Differences between HP-9114A and 9114B Message #3 Posted by Grant Goodes on 26 Aug 1999, 6:00 a.m., in response to message #1 by Luis
I have one of each. The 9114B is cosmetically identical to the "A" model, and the only observable software difference is that it responds to the "ID" command with the different model number. Internally, you can see that the electronics of the "B" model is somewhat simplified. I have read (though not verified with personal experience) that the "B" model uses less power, and thus should have a longer battery life when in use. I have a manual for my "A" model which gives predicted battery lifetimes, so if someone has a "B" model manual, we could compare the figures.
Note that both models use _only_ the old single sided diskettes, and have identical formatted capacity.
grant..
