Re: HP49G Message #2 Posted by Steve Simpkin on 4 Aug 1999, 3:27 p.m., in response to message #1 by Andreas Stockburger
Go to http://hp48.ml.org/ (www.hpcalc.org) to answer all your question on the HP49G.
More specifically go to http://hp48.ml.org/hp49/docs/faq/ for the HP49G FAQ.
And yes there is NO IR port. They used the high output pin which used to drive the IR LED to control the Flash chip write voltage.
