Re: HP35 Repair Message #2 Posted by Kevin Hilbiber on 3 Nov 1999, 3:04 p.m., in response to message #1 by Joe Uridil
I too have an hp35. what is/are the symptoms of yours? when i got mine, nothing went. there was corrosion on the machine pin sockets between boards, and when i replaced the sockets, the wall adapter worked the calculator.
however, if it works with the charger but not batteries, we are in the same boat. on mine, the switching supply doesnt work. i am hoping at some point to find out why.
for what it's worth, mine is the third one made, with dad's name where Hewlett-Packard went on all succeeding models..thats because dad designed the diffusion process that allowed lsi to build a multi function handheld calculator in the first place, and worked closely with the project throughout. so i do want to get the unit up and going again, on all cylinders so to speak. hope i shed some light on your predicament.
kevin hilbiber
