Re: HP-IL technical info request Message #8 Posted by Joe on 1 Nov 1999, 2:40 p.m., in response to message #1 by Steve
There are a LOT more documents about HP-IL that are available. The BEST source is one of the HP 82166C kits. It was a kit of parts intended for use in designing HP-IL into other devices. It contained most of the parts to built two HP-IL interfaces (HP 82166As) and ALL of the available HP-IL documentation along with a good supply of developer's tools such as HP-IL Development modules for the HP 41. I have one of the kits and here is a list of what's in it. I wrote list for something else so it's not formated for this page and it contains unrelated info.
Joe
Contents of the HP 82166 C HP-IL Interface Kit
Manuals and Media
RIOWIO Instruction Card, 2 pg. , 00075-90144 ESD Caution Card, 1 pg., 82166-90013 HP-IL Application Note Firmware Design for HP-IL Devices, 82166-90024 HP 82166C The HP-IL Interface Kit Technical Guide, P/N 82166-90020 Rev B, May 1983 HP 82166A HP-IL Converter Technical Manual, 33 pg., P/N 82166-90002, Nov. 1982 The HP-IL Interface Specification, P/N 82166-90017, Nov. 1982 The HP-IL Integrated Circuit User's Manual, P/N 82166-90016 Rev B, Nov. 1983 HP 00041-15043 HP-IL Development Module Owner's Manual, P/N 00041-90449 Rev B, Oct. 1984 HP 82165A HP-IL/GPIO Interface HP 81266A HP-IL Converter Manual Supplement P/N 82165-90012, Oct. 1982 *** Bound manual. I have another of these dated 1982 that is not bound.. HP-75 User’s Library Solutions I/O Solutions, 47 pg., 00075-90122 THE HP-IL SYSTEM: An Introductory Guide to the Hewlett-Packard Interface Loop; Gerry Kane, Steve Harper and David Ushijima, 105 pg., ISBN 0-931988-77-2
One tube of HP-75 magnetic cards labeled “Hewlett-Packard RIOWIO”, 00075-12025 One tube of HP-75 magnetic cards labeled “Hewlett-Packard I/O Utilities”, 00075-12022
Components
One short tube containing 4 HP-IL pulse transformers P/N 9100-4226 Four plastic bags each containing 1 HP-IL panel receptacle P/N 0950-0852 One plastic tube containing 4 HP-IL Integrated Circuits P/N 1LB3-0003 AND 2 Micro Processor Integrated Circuit P/N 1820-2810 One plastic bag containing 8 #2 self-tapping screws and washers P/N 0624-0302 and 3050-0626 One plastic bag containing 8 15K Ohm 5% .25 Watt Resistors P/N 0683-1535 One plastic bag containing 8 383 Ohm 1% .25 Watt Resistors P/N 0698-3446 One plastic bag containing 4 .1 Micro Farad Capacitors P/N 0160-0576 One plastic bag containing 4 120 Pica Farad 5% Capacitors P/N 0160-4800 One plastic bag containing 4 56 Micro Henry 5% Inductors P/N 9100-1631 One plastic bag containing 8 1N973B Zener Diodes P/N 1902-0970 One plastic bag containing 8 6.2 Volt 1N753A Zener Diodes P/N 1902-0953 One plastic bag containing 2 4 MHz Crystals P/N 0410-1305 One plastic bag containing 8 330 Pica Farad 5% Capacitors P/N 0160-4292 One plastic bag containing 4 10 Micro Farad Capacitors P/N 0180-3135
Note: The manual says that kits assembled after the second quarter of 1983 should include 4 HP-IL hybrid networks P/N 1810-0651 instead of some of the separate components. I have one kit with separate components and another with the hybrid parts.
Note: The manual says that the microprocessors are included so that the builder has the option of building an interface which duplicates the function of the 82166A HP-IL Converter. Note, that although there are enough parts to build four interfaces, there are only two microprocessors and no cases or circuit boards.
Two plastic bags each containing 1 HP-41 HP-IL Development Module
