Re: 41CV locked in Prgm Message #2 Posted by Dan Grelinger on 25 June 1999, 10:11 p.m., in response to message #1 by VinceC
The reset function for the newer -41's is pressing ON and Enter at the same time. If that does not work, try ON, enter, and CLX. If that does not work, and you are able to turn it off, do so, hold down the CLX key, and press and release the ON key, and then release the CLX key. If that does not work, remove the battery pack, and get a short wire (straightened paper clip works fine) and short the battery terminals. The press the ON key and the Enter Key simultaneously again. Don't put the batteries in until 24 hours later. If all of that does not work, then it may be bad. It could be tested with the diagnostic module, several active people on this forum have one.
