Re: HP-15C LCD repair? Message #4 Posted by orbital1 on 3 June 1999, 10:38 p.m., in response to message #3 by Anthony Paganini
that sounds like a later unit, which is more difficult to repair. you can peel up each of the rubber feet and remove the four screws. careful, two small springs will fall out! i believe a 15C of that vintage will have all the parts mounted on a single PC board, which is also part of the keyboard. to access the display, you have to break all the heat stakes that hold the keyboard together. if you get that far, a display from a similar age 12C may work, but have fun getting it back together...not!
