Re: HP 9114B Battery Message #2 Posted by john on 10 May 1999, 10:09 p.m., in response to message #1 by jeff
Matter of fact, I just went through this myself. The drive will *not* run or pass the self test on the charger alone, without a good battery. The best (only) replacement I have found so far is from Batteries Plus (www.batteriesplus.com). Their Hawker Sealed-Lead Cell 0810-0102 works for a replacement. Note: this is just the battery replacement, not the whole battery pack. You have to open up the old battery pack, (you need a #T9 torx screwdriver), and replace the battery inside. It's just a teeny bit thicker and the plastic case bulges slightly with this battery but it still works. You have to solder an extension on the negative lead to reach the terminal. It cost me $26 at one of their local retail outlets. Check their web site for locations. This battery is listed on their web page http://www.batteriesplus.com/prod/hawker.html but the picture on the top is wrong. No dimensions are given but it's almost a perfect replacement except for it's about 1/16 inch thicker.
