Re: Opening HP97 Battery Pack Grrrrrrr Message #3 Posted by Dan Grelinger on 5 May 1999, 10:23 p.m., in response to message #1 by Steve
I rebuilt a couple of these. I used the sub-C Replacement Ni-Cds from Radio Shack with the solder tabs already on the cells. It was a tight fit, the solder joints must not use much space, or you will have a hard time getting the plastic case back together around them. If Batteries Plus will do this for $20, it is well worth it.
