Re: HP 67 battery charger Message #2 Posted by DaveC on 18 Apr 1999, 5:13 p.m., in response to message #1 by Paul Davis
I'd actually buy an existing stabalised supplyand change that. The only additional component you need is a current limit resistor and a power diode. The important operating voltage is that that runs the calculator which needs to be set accurately at 3.75 to 4 volts. The additional diode and resistor can be used to form a charging circuit direct from the secondary of the transformer. I'd choose the resistor to pass C/10 to C/15. (C=Capacity of cell).
