Re: Sqeak of the 48G Message #2 Posted by Steve Borowsky on 15 Apr 1999, 11:35 p.m., in response to message #1 by iqbal
What do you mean by squeak? Do you mean a mechanically induced sound having to do with the physical casing or an electronic sound? If you're talking about a sound produced by the mechanical looseness of the two case halves, I would say that is a by-product of the calculator being held together by heat stakes and not allowing for tightening as would be the case using screws. If the case halves weren't fully mated during assembly there may be some play between them that produces a sqeaking sound, perhaps when the keys are pressed.
