Re: HP 41CV with Memory Module? Message #1 Posted by Dan Grelinger on 14 Apr 1999, 10:31 p.m.
The short answer is.... NO
The long answer is; the 82106A is to be used with the HP-41C only, and up to 4 could be used. The HP-41CV already had all of the standard memory that was available with this machine. The 82180A Extended Functions/Memory Module and the 82181A Extended Memory modules could be used with the HP-41CV. The Extended Memory was "off-line" as in files, that could be read into regular memory.
