Re: Cracked Display Message #3 Posted by Paul Brogger on 27 Mar 1999, 6:16 p.m., in response to message #1 by Tod Lewis
Buy a used HP-48G on eBay (or elsewhere) & swap circuit boards. It's possible to open the HP-48G(X) without noticeable external cosmetic damage (there are web pages describing the process, and I've done it twice), and it should be possible to take the circuit board off & replace it. (See my post elsewhere in this forum about how to open the HP-42S -- it's essentially the same process.)
A -48S might be available for a bit less, but you'd want to be confident they use the same LCD.
Good luck!
