41cx and xrom functions Message #1 Posted by dave on 25 Mar 1999, 9:48 p.m.
greetings to all that are hp! here's my scenario...trying to copy a program from an application module into extended memory and then running the program without the module. have worked through the cx manual, to no avail. so far, I have been able to copy the program into main memory, then using "savep" it is sent to extended memory. then, with the module unplugged, I use "getp" to bring the program into main memory, then try running it.....which brings up "nonexistent".....I figure this has something if not everything to do with the program looking for the modules xrom address, so question is, what to do? better yet, is this possible? any help would be appreciated!
keeping the faith, dave
