Re: 82143A (Thermal) Printer Problem Message #2 Posted by Dan Grelinger on 28 Mar 1999, 5:04 p.m., in response to message #1 by Wayne Brown
Wayne, I know enough about the printers to be dangerous. I can think of three things that may be wrong with your printer; 1. Thermal heads worn out. HP claimed that non-HP paper was rougher than genuine, and could wear out the thermal heads faster than genuine HP paper. This would indicate that extended use on any paper would wear out the thermal heads. 2. Thermal heads are dirty. 3. (Most likely) Misalignment of the printer head with respect to the printer roller, and therefore paper. This is likely since the two nonfunctioning pixels are together, at one end. I am not sure how you would fix this, sorry.
