Re: hp-41cv Message #2 Posted by Wayne Brown on 13 Mar 1999, 12:39 a.m., in response to message #1 by Chuck Ratliff
The instruction card that came with the 82120A battery pack recommends 12 to 16 hours for a full charge. It also recommends disconnecting the pack when it is fully charged, using it until the low battery indicator comes on, then fully charging it again. There is a warning that leaving the charger connected at all times will greatly limit the capacity of the battery. (Normal capacity is 6 to 12 hours of continuous program-running on a full charge.)
Of course, this is assuming the pack is factory original; if the pack has been rebuilt, then capacity and charging time will depend to some extent on the type of replacement cells used. In that case, whoever rebuilt the pack should be able to provide details. I'd assume that the standard instructions still would be at least close to optimum.
