Re: The "pinch-wheel" of your 65, 67, 97 is gone ? Here is the cure Message #1 Posted by David Ramsey on 7 Mar 1999, 12:13 a.m.
Did you use two rings on the wheel? Gianamaria kindly sent me some of the one he's used but I've had no luck getting the card reader in my HP-97 to work with them...
Re: The "pinch-wheel" of your 65, 67, 97 is gone ? Here is the cure Message #2 Posted by Marwan Joury on 11 Mar 1999, 8:18 a.m., in response to message #1 by David Ramsey
Yes, I did use two rings on the wheel. Had no problems.
